So before I tackle the stat problem another one has cropped up...
Flashing glow plugs and "Engine Workshop!" error on dash this morning. Engine turns over but won't start. Call the RACV - no fault codes pop up on the VAGCOM. After checking the fuse boxes - fuses SC26 and SC33 also blown.
Looks like it is a failed ECU which is apparently a common failing part for the 2.5TDI. Prior to this, it had been intermittently difficult to start and had other intermittent issues with the central locking which is also an indicator of the above.
My question - has anyone had to replace/repair the ECU and approx how much was it?
