If you install 2 batteries in parallel, just connected with the wires and nothing else, you will put quite a load on the alternator, if both batteries would be flat and when you will use your second battery the current will flow from the starting battery and you probably won't start one day. Also, the connecting wires would have to be quite thick at least the same as the battery cables that are in the vehicle now.
The 12V to 12V charger has advantage that you don't have to run the starting cables from your main battery, you only need cables that are for 50A current. I used 150A cable from the battery positive to the 12V to 12V charger under the front bench seat, so I can use the AUX battery in emergency for the start up. The 12to12 charger also allows to charge batteries with different chemistry and it's usually 3 stage charger, much better suited in long term.
