Results 1 to 10 of 116
Thread: Dual Battery Options and Fitting
    May 2022
    Quote Originally Posted by Pickle View Post
    I'm looking at doing the same thing and will use the Ctek smart charger with solar option. easier to spend more now that have to revisit the job in the future.
    12V Bundle Multi Tool Smart Battery Charger | CTEK | Edisons
    Thats a high price, look on ebay for a cheaper price.
    When I removed my dual seat I found a nice big fat positive cable all taped up under the seat so i hope thats a direct connection to the battery so i don't have to run a new cable. I've replaced the twin seat with a single as i want the walk through function, that means I may have issues finding a home for the second battery.
    I would go for a fully sealed battery maybe a AGM around the 80Ah size so it can run your freezer for a while off line, I will be using it for similar uses to you, freezer, lights and power.
    Would be interested to see how you go.
    Pickle, I am looking to do this exact thing. My T6 has bench seat and 2nd battery options fitted as factory, but want to go to swiveling passenger capt chair. Wonder how I will get on re-siting the 2nd battery.
    Cheers TimBat
    Feb 2017
    Gold Coast
    Quote Originally Posted by timbat View Post
    Cheers TimBat
    If you disconnect the sensor on the negative ( - ) terminal of the cranking battery, you do not need a DC/DC device and the auxiliary battery will charge faster.
    I actually have a lithium auxiliary battery and have been running this setup for 18 months now.
