Ive got a 2017 model with the factory Aux battery, it was only a $500 option and at the time the dealer didn't now much.
It came with a 75 ah battery from memory, i measured the voltage into the battery while underway and it put out 14.55 volts (mine is a euro 5 engine)
I had swivel seats installed and the engineer replaced that battery without my knowledge with a 63 ah battery as the swivel module was close to the battery terminal.
I ended up, disconnecting the aux battery and removing it and installing a Votronic DC-DC/solar/230 volt charging system and installed two 140ah AGM in parallel in the rear of the vehicle under the camper bed
Its a camper and the max size AGM i could put under the seat was 100ah
If you only need a small amount of power, its handy, but if you are building a camper, you might need more Amp hours
but at $450... its worth getting if you need a Aux battery and don't want to pull the cab apart to run cables.
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
