Syncrotek : Hi - good response to this odd problem!
I'm not sure what you mean by the "terminal 30 voltage supply relay"- but then I'm not familiar with how a Multivan is wired. Does this car have a T30 relay - or are you referring to the T15 relay (J329) that energizes the T15 rail voltage when the ignition key is moved from the OFF position?
