Results 1 to 10 of 10
Thread: Driving T5 with passenger seat removed - error reset?
    Mar 2014
    Greenbank,Qld
    Currently installing inverter for 240 volts, under the passenger seat in a T5 camper conversion. I have been disconnecting the vehicle battery before disconnecting the seat airbags, reversing the procedure when putting things back.
    Now I want to drive the vehicle to a friend's for some help with wiring. I'd like to leave the seat out while I get the vehicle to the friend's place. I anticipate a Check Airbag warning should I start the vehicle with the seat removed. Would I have to get a service centre to reset the check light? Hoping someone has come across the issue.
    Iza
    Dec 2006
    Kilsyth, VIC
    You need someone with a basic code reader/reset tool like VCDS, OBD11 or a stand alone hand held tool (or lots of other simliar options). I'm sure there is someone on here that could help you out with a quick reset:
    http://www.vwwatercooled.com.au/forums/f153/
    Mt Cotton
    I am not 100% sure but if no one sits on the seat it may not show up . If you need recoding resetting Alba European at Slacks Creek has the gear or K& G Automotive also in Slack Creek could do it as well .
    Mar 2014
    Greenbank,Qld
    Quote Originally Posted by The_Hawk View Post
    Ta, I will chase that one down.
    Iza
    Mar 2014
    Greenbank,Qld
    I'm intending to take the seat out completely and leave it in the shed while I drive the vehicle to the friend's place. I anticipate the check light will come on during initial checks by the vehicle computer when I start the vehicle.
    I have noted the suggestions for someone that can do a reset if I need it, thanks.
    Iza
    Dec 2008
    Sydney/Canberra
    With the seat out, you will get the airbag light on, and it will need to be cleared once the seat is re-fitted.
    Mar 2014
    Greenbank,Qld
    I'll contact a couple of those suggested reset places and ask prices. I's like to leave the seat out for a short drive but cost might not be worth it.
    Another thought - is there any plugin available to fool the computer, that you know of?
    Iza
    Mt Cotton
    I'm not certain but you could disconnect the battery leave it off for a while refit the seat and then reconnect see if the light has gone out , I know it works with some things .
    Dec 2008
    Sydney/Canberra
    Negative.
    Disconnecting the battery will just bring the light on for low voltage reasons.
    There's really no other way around this, besides not reconnecting the battery without the seat plugged in.
    Mt Cotton
    Bloody Vw , thanks Umai I did say I was not certain but it has worked on other cars for me over the years with electrical glitches .
