Not yet but it makes sense I read somehwere that the DPF will block up and then obviously for the van to maintain the peformance it will use more fuel until it regens . One theory was that as the DPF starts to block the exhaust fumes behind the filter can cause the engine to heat up more than normal as as the blockage ocurrs the engine is struggling to get the gases out and could cause the manifold to crack . I am not a fan of this myself it seems that car makers are constantly building systems that are designed to do a job but in themselves they can lead to even more problems as they can cause breakdwns as has been reported by quite a few VW owners .
