Results 1 to 5 of 5
Thread: Double DIN head unit
    Sep 2010
    Penguin, Tasmania
    Has anyone tried to fit a double DIN head unit into the dash of a T4?
    I have read on some overseas forums about there not being room behind the pocket under the factory radio, but some difference between left and right hand drive models.
    Does anyone know if this will work with the Aussie models?
    Cheers,
    Jim
    Dec 2009
    dont think it would be an easy job...im pretty sure these a metal bar supporting the dash or something behind the pocket...you'd need to do some cutting to fit a double din. although please do let me know if you're successful in fitting one in as i'd like to do the same!
    Sep 2010
    Penguin, Tasmania
    Yeh that's what I thought.
    I don't really want to go hacking into the steel work, but I would like to put an all you can eat style of unit in. I have found a single DIN unit that has the screen hanging downward. That would cover the pocket OK.
    Maybe that is the simple solution.
    Cheers,
    Jim
    Dutch solution with a LHD T4
    Google Translate
    Found this while looking for something else. Looks neat but the translation mangles the instructions a bit. Hope it helps
    Mar 2008
    Central Coast but currently living Bosnia
    Nice one would be my last resort, but doing it that you can keep the head unit cool in summer with the vents behing it,
    2010 Jetta 2.0l TDI 103
    2010 Passat CC 2.0l TDI 125
    2011 Passat 2.0l TDI 125
