Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Door lock deadlock release T5 2005
  1. #31
    Dec 2008
    Sydney/Canberra
    I just use a bit driver.
    Skinny enough to get in there.
    Supercheap sell long T-handle Torx sets, which I needed to buy, to do a similar job on a Mercedes Benz A-Class. Was about $35 for the set.
  2. #32
    Apr 2014
    Chelmer, Queensland
    Before I commit myself further now the lock is out of the vehicle, I would appreciate some guidance.
    Once I give it the kiss of life, I hope that I should be able to activate the lock before refitting it by plugging it into the door loom. Is that correct?
    When I removed the lock I found that one spring seemed to be out of position. It was butted against the black casing shown by the smaller arrow, not in the lever notch where I repositioned it.
    Door lock deadlock release T5 2005-p1040389-jpg
    It may have bounced out when I disconnected the external handle, but with it positioned where it is, there is significantly extra effort needed to pull the outer handle cord.
    Did I do right or wrong repositioning it?
    Any chance it had anything to do with the locking issue (clutching at straws)?
  3. #33
    Mt Cotton
    No incorrect it should be same as this one in our van .I have a load of other photos showing dismemberment if you need them ?Door lock deadlock release T5 2005-20161212_171610[1]-jpg
  4. #34
    Apr 2014
    Chelmer, Queensland
    Thanks. Wonder what the slot is/was for?
    I might leave dismemberment until I find a bottle of Bourbon, but it does look very final.
    I'll PM you with my email if you'd prefer not to drop them here.
  5. #35
    Mt Cotton
    This part of how I approached the job , strong glass of bourbon the pick axe ? dare you ask well I had considered using it to jam between the door inner skin and the pillar to force the door open as you may recall this sucker was closed and locked in the deadlock position making access almost impossible .
    Door lock deadlock release T5 2005-20161212_165111-jpg
  6. #36
    Mt Cotton
    Not sure what has happened here but if you cant see the photos let me know .Attachment 27543Attachment 27544Attachment 27545Attachment 27546
  7. #37
    Mt Cotton
    Ah ha if no text no photo , sorry there not in order , one important thing when reassembling the electric motor part ensure the parts are engaged correctly . The first time I did it the lock would not work properly so I had to redo it a second time and then it was perfect . There is a locating guide that goes into the green part as it locks and unlocks it move from one slot to the other .
    Door lock deadlock release T5 2005-20161212_172033-jpg
    Attachment 27549
    Attachment 27550
    Attachment 27551
    Attached Thumbnails Attached Thumbnails Door lock deadlock release T5 2005-20161212_172438-jpg
  8. #38
    Apr 2014
    Chelmer, Queensland
    Know the feeling. I dropped one of my plastic door card removal thingees in the latch on the B pillar as soon as I got that door open. The SOB wasn't going to lock on me again.
    Thank for the pics.
  9. #39
    Apr 2014
    Chelmer, Queensland
    Sunny,
    I've cracked the lock apart & tried test assembling it before I start messing with it, but I have 2 issues:
    (1) I can't understand the function of that green plate under the worm drive. When I dropped the case apart, it was operating in the left track, but I see that it has a spring that can toss it into the right arm of the Y. Do you understand what function it performs.
    (2) I can't slip the two halves back together. The shroud around the pin that sits in the top of the worm & drives the door open indicator doesn't want to slip around the base of worm opening. Did you have that issue & what answer did you come up with.
    (3) There seems to be a certain amount of carbon around the two breather holes in the motor. I hope that doean't have any meaning.
    John
    Door lock deadlock release T5 2005-cracked-jpg
  10. #40
    Apr 2014
    Chelmer, Queensland
    OK, I give up. I got all the electric bits & their case in a ready-to-go-if-they-ever-will status & had a last fiddle to prove the mechanical side of the lock - and suddenly the bloody thing won't unlatch when the yellow disconnector is raised and either of the door pull levers is activated. That's not quite true, it does it one time in 10 & that's not enough for me to trust the damn thing when I reassemble everything.
    A second hand lock with a 6 months warranty is on the way. I should have done that a week ago.
