Powered by the electronic ignition.
That would more than likely be a sticky instrument movement at a guess.
Just to add - if it sticks again when turned off, give it a tap on the glass or around the instruments to see if it moves back to O.
1995 T4 petrol 2 ltr. does the tacho run off coil or alternator ?. The issue I have is that the tacho has become very 'jerky' in its movement and when i turn ignition off it stays on 1000 rpm. (the dial not the motor) if i then just flick ignition on and off again the dial goes to zero !! any thoughts ?
It will be the servo motor in the cluster as these do play up and act as you described.
Have you tried hitting the top of the dash?
Probably won't fix it as such, but it'll maybe confirm where the problem lies.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thanks all, hitting the dash worked fine. Went for a long drive today and all seems to have settled.
