Results 1 to 6 of 6
Thread: Does tacho run off coil or alternator ?
    May 2015
    Sunshine Coast
    1995 T4 petrol 2 ltr. does the tacho run off coil or alternator ?. The issue I have is that the tacho has become very 'jerky' in its movement and when i turn ignition off it stays on 1000 rpm. (the dial not the motor) if i then just flick ignition on and off again the dial goes to zero !! any thoughts ?
    Jun 2012
    NSW
    Powered by the electronic ignition.
    That would more than likely be a sticky instrument movement at a guess.
    Just to add - if it sticks again when turned off, give it a tap on the glass or around the instruments to see if it moves back to O.
    It will be the servo motor in the cluster as these do play up and act as you described.
    May 2015
    Sunshine Coast
    Quote Originally Posted by Syncrotek View Post
    OK thanks for that, will try next time
    Dec 2008
    Sydney/Canberra
    Have you tried hitting the top of the dash?
    Probably won't fix it as such, but it'll maybe confirm where the problem lies.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2015
    Sunshine Coast
    Thanks all, hitting the dash worked fine. Went for a long drive today and all seems to have settled.
