Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 52
Thread: Do anyone still change the oil after the first 1000km on a new diesel?
  1. #31
    Mt Cotton
    Aren't you overthinking this a bit , oil testing etc failures are going to happen for a variety of reasons and oil would probably not be the cause , I had two engines changed by my Ford dealer before my VW days both of them in two vehicles bought years apart were a result of manufacturing faults . How long are you going to keep this one for ? My current work T5 van has clicked over the 306000 km mark and 12 years for a pissy little 2.0 petrol model , I will admit here that it,s oil level gets low from time to time but only a fool would expect similar oil consumption from when it was new . At times when I have heard the first start with a slight rattly sound {indication it needs a top up } I have some times grabbed a container of oil laying around to top it up with which obviously does not have the same numbers VW recommend . The old girl is still going strong despite my sometimes negligent ways HA HA , don't ask about the clutch though a whole new chapter there . Ok some will say well if it had blown up you would only had yourself to blame , well even our other van now sold has 200000 kays on the clock and it has over $18000 worth of repairs required over ten years leaking turbo failed air con compressor failed transmission due to manufacturing fault and design failed intercooler connector due to faulty design so it goes on and on . Car makers aren't yet perfect .
  2. #32
    Jul 2016
    Sunny i do overthink things, but i do plan on keeping this van for a while and its small money to have clean oil after the first 1000-2000km.
    As for a the oil test, I've seen enough info to see that the CFA bi turbo engine has a few issues, My engine has the modified parts, whether this works or not is to be seen.
    But having oil test records can pick up is something is not right, hopefully before failure, and also its written technical record of the elements within the oil, if i ever have to go down the path of good will after warranty.
    With most things, preventive measures often reduce more $$$ issues in the future.
    Having said that, the engine is just one component, I've seen the issues you have had with your transmission and other bits.
    Car makers will never be perfect, we expect to much out of corporations that only care about the bottom line.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
  3. #33
    Adelaide hills, SA
    I also change the first oil in transmissions and diffs at 15,000km-20,000km. Very cheap insurance indeed.
  4. #34
    Jul 2016
    I was looking at doing that as well, as oil is cheap insurance.
    I did that with my Can Am Commander SxS motorbike, and the crap that was in the diff oil change was not good, heaps of swarf, i changed it out at 10 hours for initial run in, same with transmission.
    Plus after changing to better oils, the noise reduction in the diffs and the smoother transmission change was an added benefit.
  5. #35
    Jul 2016
    If anyone needs oil.
    I noticed yesterday, that Supercheap Auto have Castrol Edge 5w-30 5 Litre that conforms to VW 507.00 on sale
  6. #36
    Aug 2016
    NSW
    Last time I tried to buy any 507 spec at Supercheap, Nulon was the only one in stock.
    All others were order in.
    After that, I just get the Nulon in 20lt drums from my local bloke.
    Works out at half the price of buying in 5 lt bottles.
    2018 Crafter Runner
    T5.1 6sp manual.
  7. #37
    Jul 2016
    Quote Originally Posted by LogicprObe View Post
    That 20 ltr drum works out well, it might depend on where the Supercheap is, they had at least 8 tubs of the Castrol when i was in there looking for paint.
    i always find with almost everything, if i need it, it isn't on the shelf and when i don't need it there is heaps
  8. #38
    Adelaide hills, SA
    Just keep in mind that even synthetic engine oil has its use by date and it's NOT from the moment you've bought it.
  9. #39
    Apr 2017
    belgrave victoria
    Hi guys
    I am getting a new diesel alltrack in a month i have a specialist vw mechanic that looks after my familys vw's (5 in family total 4 golf's 1 polo) rang him yesterday and from what he has heard he recomended not changing oil till 15,000km (passing up a easy service charge for him to!) will be getting my new car done by him from new so will take his advice
  10. #40
    Apr 2013
    Upper Gully VIC
    Quote Originally Posted by Kachingg View Post
    ...i have a specialist vw mechanic...
    Out of curiosity, is that Boris?
    If so, he put me back onto 15,000km services when I moved to him...my local mechanic had me down to 10,000km.
    After a comment somewhere here from Transporter (I think) about "...Shortening today's long service intervals..." I asked Boris if I should have an extra oil (and filter?) change at say 7,500km...he thought I'd be wasting my money. His philosophy seems to be very much to go by the VW book.
    I'm still thinking about doing it anyway.
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
