I had this in my Cruiser Had one power lead from reverse light and another from an accessory on wire in the console.
You need a diode on each source wire, and I had a switch in the permanent lead. Worked well and easy to do if you are handy. DONT wire it off an ALWAYS ON wire unless you want a flat battery sometime down the track.
I wouldnt fit a wireless camera because of the amount of metal in a van. Had one on a caravan and it was useless. Far better to get a wired one.
