Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: DIY wireless reversing camera - permanently powered
    Adelaide hills, SA
    Quote Originally Posted by downhilljon View Post
    Thanks guys for the advice!
    Was hoping it would be a simple solution - e.g. there was a permanent power source for something at the rear of the van, but that would've ben too easy
    Haven't ordered anything yet... just thinking it through... thanks for the tip regarding wireless hillbilly.
    Transporter - I like your idea... not sure exactly what I'm looking for there though - do you have a link to what you are looking at?
    Thanks!
    Here,
    JB Hi-Fi | Navman MiVue560 Full HD Digital Drive Camera
    Jun 2007
    Melb.
    The Crafter's sister.
    I've considered the Crafter Runner first, just because I could easily tune it to 120kW and 400Nm. But there are some other differences between TDI300 and higher output Crafters, like the front stabiliser bar and the rear brakes are smaller in TDI300, this is just from the specs sheet, so who knows what else has been removed when building the Runner?
    I'm a bit slow today, so would that be a Sprinter? Would love to know what you looked at and reasons for final choice, maybe in another thread or PM if you have time?
    Adelaide hills, SA
    Quote Originally Posted by Tornado T5 View Post
    Pm sent.
    Gerringong, NSW
    Thanks transporter!
    Although I'm not sure that will work for me... I need to mount the camera externally, that looks a bit too fancy to leave exposed!!!
    2nd question: if I'm going to run a wired camera from front to rear, would it be easier to wire it up through the back door and mount it above the number plate, or run the wire out the engine bay, underneath and mount on the bumper somewhere? The internal route looks pretty fiddly...
    Pacific Paradise QLD
    When I did mine in a 100ser Cruiser I managed to fir the cable under the trim and pull it through the access sheath into the top tail door and fit the camera in one of the number plate lights. Had to use a bit of slippery to get it pulled through the rubber tube but was doable.
    Was neat and gave a good view of the towbar and a short way down the road.
    You dont want it too low or wont be able to see anything worthwhile
    Gerringong, NSW
    Yeah, above the number plate seems like the best location... just looked like the most fiddly installation!
    Will see how I go...
    Jun 2007
    Melb.
    Thanks transporter!
    This youtube vid might give some insight, professionals at work.
    https://www.youtube.com/watch?v=bMUJAkbglh0
    Gerringong, NSW
    Thanks Tornado T5!
    Very helpful
    Jun 2007
    Melb.
    No Probs....I occasionally re-watch it hoping I could do the same, lol....and then think if I wait long enough I'll buy a T6 instead.
