Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Discovering an unknown feature.
  1. #21
    Aug 2008
    Vermont, Melbourne
    So no "Brake Burnouts"?
    2008 LWB 128KW 4 Motion Transporter
  2. #22
    Jun 2009
    Quote Originally Posted by Floorshow View Post
    use handbrake.
  3. #23
    Aug 2008
    Vermont, Melbourne
    I discovered a new feature today, If you unlock the van and don't open the door after about 20 seconds or so (when the interior lights go off) the van automatically locks itself.
  4. #24
    Nov 2008
    Nth Queensland
    Yep.
    I had a scare the other day at the rubbish tip. My wife told me our T5 van had locked its self with the keys in the ignition.
    Luckily I had my window down, other wise I would have been stuffed and closed our tip as the vehicle locked itself at the only dump point.
    Wasn't there a plastic key that you could keep in your wallet for the T5?
    Best wishes.
    Ken.
    2007 T5 Van LWB 2.5 Manual remapped (White)
    2013 Amarok Highline Auto (Natural Grey)
    Nth QLD
  5. #25
    Adelaide hills, SA
    Quote Originally Posted by Baytown View Post
    Yep.
    Wasn't there a plastic key that you could keep in youe wallet for the T5?
    Best wishes.
    Ken.
    We got the plastic key with our Touareg, it's great when you go to beach.
    I'm sure there must be one for T5 too.
  6. #26
    Jun 2007
    Melb.
    Yep.
    Best wishes.
    Ken.
    How did you unlock the car and get out without opening any doors for it to self-relock because this is the only way it should happen unless there is a fault IIRC? It shouldn't have done so otherwise.
  7. #27
    Nov 2008
    Nth Queensland
    The key was in the ignition while I was out of the van with ignition off. It then locked itself after a set time.
    I had the drivers window down while I was reverse parking the trailer or I would have been locked out.
    It's a feature I'm aware of, but unsure if it only occurs with the key in the ignition, as it doesn't seem to when it's out (i.e, parked in my garage).
    I'll look into it further, including the instruction book.
    Ken.
    Nth QLD
  8. #28
    Jun 2007
    Melb.
    Ken.
    Strange one. I've sat in my van, locked it with the remote and then unlocked it, waited a bit and then had the van auto-relock. As soon as a door is opened after unlocking using the remotes it shouldn't ever try and relock itself.
  9. #29
    Aug 2007
    Perth WA
    I think that's the key to it (no pun intended)... if the vehicle is unlocked from the remote and none of the doors or boot are opened, then it relocks automatically as a safety precaution -eg in case you unlocked the car accidentally pushing the key from within your pocket etc etc.
    Didn't think you could use the buttons on the remote with the key in the ignition though? I've had the interior lights turn themselves off while working on the car after some time delay (and I had turned the lights to On it wasn't with the door sensor) so perhaps the doors will lock again even if the key is still inserted....
    '04 BMP MkIV R32 #144
    search getnew
  10. #30
    May 2009
    Hmm, electronics.
    Keep a spare key hidden under neath somewhere, just in case.
