Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Discovering an unknown feature.
    Jun 2007
    Melb.
    I'm the first to admit I haven't read my T5 manual cover to cover in the 2 years of ownership, too busy enjoying the . Anyway I thought it would be interesting for others to add features they never knew their T5 had until an accidental discovery.
    I experienced one today. I always knew that if the key is turned full left in the drivers side door lock and held there all doors are locked and all open windows are powered up while the key is kept turned left. However I found out today that if turned full right and held there the windows are powered down as well after the doors unlock. Has anyone else found a feature they didn't know existed?
    Adelaide hills, SA
    I've never used the key in lock to open my door, but I will try it today. Thanks.
    It would be better, if it could be done using the remote, but there is nothing in VCDS (Vag-com) on it.
    P.S. Tried and it does the same.
    Aug 2008
    Thanks for the tip....mine does the same!
    I also discovered that if I turn the car off with the blinker still on the buzzer sounds at me. Not real sure what the purpose of that is though.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Adelaide hills, SA
    Quote Originally Posted by Ivo View Post
    The parking light on the side you've got the indicator on is "ON", so it let's you know, if you leave it on for long time you would discharge the battery.
    Jun 2006
    Sunshine Coast
    On the skinny european roads they leave the offside light illuminated when vehicle parked as a clearance light so your van isn't side swiped by someone not seeing it.
    The window up/down via remote is an option on the Golf so maybe it could be added to the Multivan via vagcom, can you add instructions?
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
    Aug 2008
    Cheers mate, now I know!
    Aug 2008
    Vermont, Melbourne
    Quote Originally Posted by coastie View Post
    The Caddy is also able to do this via the remote.
    2008 LWB 128KW 4 Motion Transporter
    Aug 2007
    Perth WA
    Haha this again
    *Listens to the sounds of pennies dropping as people suddenly realise why parking lights are actually called as such or 'parkers' for short lol*
    I think the key + hold feature has been available since Mk III Golfs so probably on equivalent generations of other models since the same time as well. You can add the remote + hold feature to Mk IV remotes via software but it's not a VAGCOM on/off type feature. Do a search for "kvw100" as that aftermarket gadget may suit other models not just the Golf et all platform. Fuzion has a few for sale at the moment too.
    '04 BMP MkIV R32 #144
    search getnew
    Adelaide hills, SA
    It appears to me that it doesn't have the controller or option for that to be changed in VCDS.
    Aug 2007
    Perth WA
    Yeah that's it. The kvw100 gadget reprogram the central locking functions directly to the ecu, bypassing the VAGCOM 'switches' which are just on/off settings. I'm sure some of the other aftermarket cables & software would allow you to directly reprogram as well - if you know how!
    search getnew
