Results 1 to 10 of 12
Thread: Different opinions on T4 syncro gearbox - what's the truth?
    Jun 2011
    Vic
    I've been told two different things about the T4 syncro gearboxes.
    The first thing is that they are totally different to the standard T2 FWD box.
    The second thing is that they are the same as the FWD box but with a bolt on transfer case, so you can bolt this transfer case onto the FWD box to make a syncro box.
    I've searched the WWW to little avail to find out if the latter is true. My interest is that I want to find out the options for a gearbox replacement if the worst should happen.
    May 2006
    Adelaide South Australia
    What is a T2 FWD box?
    Numerous Mk1 Golf diesels
    Jun 2011
    Vic
    Sorry T4 FWD box, which I believe was 02B and the Syncro was a 02D
    Hello mate They are almost the same The O2D has a slightly modified case to accept the transfer case and also to flow oil to and from the transfer The diff also has a modification to send drive to the transfer Aside from that and slightly different gear ratios for the syncro they are essentially the same gearbox
    Not sure what you are trying to do but fitting an O2D to a FWD only car you will need to upgrade the sump
    The transfer also has a rear support bracket which attaches to the block Worth checking to see if it has the mounting holes
    Jun 2011
    Vic
    I have a T4 dual cab syncro and would like to put a bit more power through the gearbox. I've been told (by Dande Volks) that they are a bit fragile in a bearing, particularly when people try to use 5th gear to slug their way up a hill. So I'm just concerned about how to replace the box if it goes bad. There are plenty of FWD T4's in a local pick a part wrecker, but not many Syncro's.
    Jun 2006
    with the dust and flies in western Victoria
    If you kill the box internals then you'll be fine in terms of parts. However, if you wreck the case in the process then you'll be in trouble.
    Bear in mind that you're also expecting the VC and rear diff to cope with the extra torque.
    Mind you I reckon if you are staying within a 10 to 15% increase then you'll probably be fine...margins for error being what they are.
    Jun 2011
    Vic
    I hope so, but I'd be looking for a 20% increase in torque to make the effort worthwhile. Most fo the time it is not required, but on some occasions another 50nm would be handy on a hill just to be able to accelerate past a truck etc.
    Jun 2006
    The thing to bear in mind is that your petrol engine never produced the torque that the diesels did - mine knocked out 250 torques when it was new. Even the 5 cylinder petrol engines only managed 200 torques tops and the four cylinder engines 160 torques. I reckon you'll be fine.
    Jun 2011
    Vic
    Thanks.
    Dudley Park, WA
    I had an interesting chat with a mechanic the last time I was back in the UK, he had done his apprenticeship with VW and spent a good 20 years working on them, so I'd say fairly reliable information... He told me that the T4 Syncro boxes are good for about 200bhp and only really get reliability issues over that. Taking into account the most powerful engine made for the T4 was the 149bhp TDi engine with 295Nm of torquey goodness and was also available in Syncro version on the Multivan, your looking pretty safe.
    I've done a little research into this as I own 2 syncro's, a 2.5 petrol here and a 2.4d in the UK. My final conclusion was although the diesel really needs more power(a massive 77bhp), the 2.5 petrol is pretty good and until the engine dies (I'm sure it never will!) there is little point in upgrading.
    As far as the boxes and differences go, supclean is 100% right
    T4 SYNCRO SWB x 2
