Results 1 to 10 of 13
Thread: DIESEL v PETROL
    GEELONG
    DIESEL v PETROL
    Hi Guys................if U had the choice between a 1998 T4 Double Cab in 2.5ltr petrol or 2.4ltr (5cyl) diesel...........both manual (5gears)...what would be the best choice and why ???
    Regards................DOUBLECAB :roll:
    Ps. Or neither
    diesel... more torque less fuel
    GEELONG
    Quote Originally Posted by GoLfMan
    Thanks for the suggestion ..however the specs in the REDBOOK read as follows...
    Diesel...torque: 164Nm @ 2200rpm
    Petrol...torque: 200Nm @ 2200rpm
    And the fuel consumption figures quoted are exactly the same for both engines!
    Still confused................
    in that case the only way to tell is to drive both?! that way you can decide which one is the better one for you
    Camden, Sydney
    Would the torque figures change at different rpm? If so, the diesel will have more lower down, but would rev out quick, whilst the petrol would still have some go left at higher revs. Is it for highway or town use? If I had a diesel, it would have to be a turbo.
    imported_brackie Guest
    Looney's right
    Yeah, be careful of statistics. All diesels have superior torque low down. This is why you drive them completely differently to a petrol vehicle. Also, you'll find that the gearing is different. I don't believe for one minute that the fuel consumption is the same. I think that more research is necessary (and again, the best way to decide is to drive both!)
    GEELONG
    Re: Looney's right
    Quote Originally Posted by brackie
    Hi Brackie...........yeah well thats the stats in the REDBOOK....their site is on the net.....I was told their data is correct.
    BTW: Kindly note I am comparing the 5 cyl petrol with the 5 cyl diesel (NON TURBO) engine.
    syncro Guest
    Redbooks data is definately not always correct.
    Re: Looney's right
    Aha. Well the turbo makes an enormous difference. However, the fuel consumption of the diesel should be in the order of 2/3 that of the petrol (in the hands of someone who knows how to drive it!).
    GTI-VW Guest
    Turbo diesel experience
    Go a Turbo Diesel every time.
    We drove our 2001 T4 Turbo-diesel California Coach (Factory VW Camper) around Scandinavia then down through the Baltic states to Poland, Slovakia and back to Netherlands. Averaged a shade under 40mpg with a full load of gear. I doubt a petrol version would do anything like that. Doing around 140-150 km/h on a London to Amsterdam run we dropped down to low 20's mpg. Top speed is a shade under 160km/h (indicated).
    Around town the economy is even more pronounced with the diesel able to lug along at low revs in higher gears.
Similar Threads
  1. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  2. Petrol & Diesel golf prices
    By jets in forum Mk1 Golf
    Last Post: 14-03-2007, 04:32 PM
  3. Diesel outperforms petrol
    By imported_brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 24-06-2005, 07:57 PM
