Results 1 to 3 of 3
Thread: Diesel Pump Belt!!!
    Jan 2008
    Ascot Vale
    Diesel Pump Belt!!!
    Does your T4 run as good as it did before the diesel pump belt was replaced??Does it crank for a while before it starts???
    Aug 2007
    Mine actually ran better, from what i can understand they are infinately adjustable, however the correct setting in critical. Mine starts extremely quick. Having just had mine done it appears that my fuel economy has suffered a little probably due to the slightly increased performance. I will have a better idea once i have run it for a while to get an average. So far i have only put 1 tank of fuel in it, and my driving hasn't changed, i suppose time will tell. Hope this helps
    May 2006
    Adelaide South Australia
    Quote Originally Posted by GTI_69 View Post
    It should be as good if not better. My guess is that it has not been set up correctly. Take it back & ask them to connect to VAG COM to read the actual timing.
