Results 1 to 10 of 10
Thread: Diesel Idle
    Mar 2012
    West Ryde, NSW
    Diesel Idle
    I have just purchased a VW Transporter Crew Van 4motion with the 132kw diesel motor.
    Can anyone tell me what that idle speed should be for a diesel motor like this?
    It is currently idling around 900rpm which seems way too fast to me but not sure as it is my first diesel.
    Andy
    Jun 2011
    sydney
    yeah most of them are around that
    Mar 2012
    West Ryde, NSW
    Thanks for that info.
    Adelaide hills, SA
    It's 760 ± 100 rpm
    Mar 2011
    Sidknee
    actually it seems to change. this engine seems to have a roll on idle of about 1000rpm that will then drop when actually stop rolling. I guess its to help save the clutch in traffic. it will also idle higher from time to time which i assume is DPF stuff
    132kw LWB Van. Not a tradie..
    Sydney NSW
    It will also idle 100rpm higher with Ac on .
    Sent from my HTC Sensation using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
    Adelaide hills, SA
    When we refer to the idle speed, we mean; car stationery, all accessories off incl. A/C and engine fan too, in neutral or park for auto, engine at operating temperature. Then let the engine rpm stabilised before you take the reading.
    Mar 2012
    West Ryde, NSW
    Thanks for the replies.. I will have to have a look at using a an OBDII reader on it to see what else I can find out.
    I have been using a Greddy Informeter on my Nissan I just sold.
    Any suggestions for use on the VW?
    Adelaide hills, SA
    You could get VCDS from ross-tech
    Mar 2012
    West Ryde, NSW
    I use a Mac and I don't think the software is compatible with Mac's so will have to see what else I can find out.
    A mate has this cable so I can get him to look at the car from time to time.
    As I Failed when ordering and did not option the MFD display and from all I can work out I can not build it in now for a reasonable cost so want something that will display fuel usage and other bits and pieces
