Results 1 to 10 of 13
Thread: decent write up for dual batteries in a t4
    thought you guys might like this, found it on my camper info search
    http://www.vwbooks.co.uk/new_camper/...ry_battery.htm
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Quote Originally Posted by DVR68U View Post
    cheers brenton
    Next time you go out into the shed, just do a head count for how many projects you have on the go. Lol.
    Looks like a tidy conversion, you going to have a crack at it?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Jun 2006
    with the dust and flies in western Victoria
    Rod's little how to's are always very helpful.
    Shame you can't do such a conversion if your T4 has A/C.....like mine. The condensor and much pipework sits in there between battery and engine.
    Even so.......I still have a dual battery setup. Although mine needs more work on the wire routing...
    yeah im going dual batteries , it would be good up the front. but i may put a biger battery in the back of the car and just run the wires etc from there. i have aircon but it might be moveable lol. first i need to buy a battery soln for the charging. i have found a good looking one for around $75 120a. what do you guys run ?
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Jun 2006
    I use a simple VSR from BEP Automotive which is tucked up on the inner fender beside the cabin air intake
    yeah ive got a split charger box coming down from ABR $80 posted 120amp should be good enough for now, i think ill just pop the battery in a case in the back for now next rebuild i might pop it under the bonnet.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Now Adelaide!!!
    Can you not put your extra battery under the front seat?
    Thats where mine was on the reimo converted van.
    Rob
    yeah you could put it under the seat, all my stuff is up the back of the van with the bed right up near the front seats so i can make a bigger area out back with the tail gate up.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Jul 2005
    May be a little better weight distribution in the back too.
    Maris
    well i got my battery isolator in and the 2nd battery hooked up. ill be wiring a extra set of lights and wiring in the radio to run off the aux battery so if i fall asleep i can still drive away in the morning, once i get a power inverter ill be hooking up my fridge aswell. ill get some pics up 2morro or once i get back from my trip.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
