by DRL installed and wired you mean what exactly?
DRL on the T5.1 is incorporated in the headlight as standard, and should not be installed separately.
Not for me but trying to help a friend , his T5.1 2012 has DLRs installed and wired but they don't work . Anyone have some ideas where there maybe a relay as I have tried all the fuses even ran my launch diagnostics but could not find any way of activating them , it did show the left and right one but when I try and activate them I get no response .
The bulbs on mine used to blow all the time on mine until I got some cheap LEDs ex China.
As soon as one would blow, the other would follow not long after.
2018 Crafter Runner
T5.1 6sp manual.
Are you 100% certain that the globes are OK? Have you pulled them out and checked them on a battery? The originals have a lifespan of 15 minutes.
Can you post up a photo of the entire headlight? Is the single bulb (H4) or dual bulb version (H7 + H15)?
Also, has it worked before? Or did he buy the car with it not working? Some people do turn DRL off with VCDS coding, could that have been done previously?
In my Amarok (similar design) the H15 bulb (could be the H7 need to check) doubles as the DRL .... so as per syncro's question do all the bulbs work (low beam and high beam)?
