Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Dash Instrument Panel Blanking Out -
    brisbane
    so is it still doing it after the dash cluster replacement or are you waiting for parts
    Nov 2007
    QLD
    From an electrical point of view, a short is extremely unlikely as it would just blow a fuse and stop working permanently. A more likely scenerio is that something that supplies power to the cluster is going open curcuit intermittantly. I once had a problem with the blinkers and electric windows and air-con intermittantly stop working, and the fault never reoccurred simply by moving, or reseating as I call it, all the fuses and relays in the fuse box that in hidden under the battery holder shelf in the motor compartment.
    Brian
    Oct 2010
    Qld
    Quote Originally Posted by bushnut View Post
    Cluster is being replaced - all keys will re-coded and all the other warranty jobs nailed in the same run.
    Nov 2007
    QLD
    Quote Originally Posted by question? View Post
    Ah, so it's not replaced yet, hope it fixes the fault.
    Brian
