Results 1 to 10 of 35
Thread: The Cursed T4
    Camden, Sydney
    Quote Originally Posted by DUB 20V View Post
    just torch it that wil fix it lol .
    Trust me, that has crossed my mind.
    Canberra
    Some random, oddball thoughts which may (or may not) provoke a productive line of thought (admittedly all weird stuff, but that's because you seem to have covered most of the conventional suspects already) :
    What was the immediate prior history ? eg it was starting and running OK until we changed the timing belt (or whatever).
    Is the spark "OK" when under compression (as opposed to when the spark plug is sitting outside the combustion chamber) ie is it still producing a reasonable spark when the plug is in the head ?
    Is the spark being produced at the correct time (and not 360 degrees out of phase - it would still look OK on a timing light if it was happening on the exhaust cycle rather than the compression/ignition cycle ).
    Does it have a crankshaft position sensor ?
    Any sign of an aftermarket kill switch (typically on ignition or injector electrics) ?
    Are the plugs getting wet with petrol, or just damp ?
    Blocked exhaust ? (although I would expect it to start and run for a few seconds at least).
    Is air being sucked into the cylinders and blown out through the exhaust ?
    Is there a broken engine mount allowing the engine to move so much it is allowing something to touch or stretch too much, thus stopping the engine from starting ? Try levering the engine into a different position and see what happens (this is one I have known to happen to a petrol T4 - drove the owner nuts for 18 months or so).
    Well that lot will give you some things to investigate for a while anyway, let us know what it turned out to be when you do get it fixed (even if it is embarassing for you , as that will add to the collective knowledge pool )
    Nov 2007
    Tend to agree with gregoz.. I'd lay bets its a sensor, more than likely a crank or cam sensor (if fitted). When hitting a brick wall like this I always find its best to leave the problem and walk away for awhile, then when you get back to it a solution normally presents itself. Good luck with it though and let us know what is was when it gets running again.
    GOLF GT SPORT TDI SUNROOF, XENONS
    Camden, Sydney
    Plugs are wet, almost like overfuelling, but it could be cos we have cranked it for so long.
    It does not have a crank angle sensor.
    It could be an intake sensor.
    I thought there would be an immobilizer, but the under dash loom looks virgin and unmessed with!
    I`ll keep you posted.
    Canberra
    Might need to dry plugs and combustion chamber and try again, petrol just won't burn if there is too much for the available air (seen that in action on Mythbusters - just goes to show you can learn something useful from watching TV ) . Just watch out if you crank it over with the plugs out and sparks still happening - you might just get the right air/petrol ratio outside the combustion chamber, add ignition source and BOOM !!!
    If it was a working (non VW) immobilizer then I'd expect no petrol and/or no sparks at all.
    Mar 2008
    A couple of other suggestions.
    Is the knock sensor (s) connections OK. It will not run if these are not connected or have faulty connectors.
    Is the Mass air flow sensor/air flow meter connected?
    Cheers,
    Scott
    Camden, Sydney
    We removed the plugs and cranked the motor to remove all fuel and then fitted new plugs earlier in the piece. It still made no noises. Bizzare. It has spark, although it is not super stong.
    I`m thinking MAF more and more. Am gonna need to find a starter first.
    Aug 2007
    You mentioned oil pressure - not so common on the T4 but ive had a couple of A4s and Golf Gti doing the same. The oil pressure was too high keeping the valves open. Took agaes but when it was discovered the oil filter was slackened to lower the pressure and it ran, pissed oil but pinpointed the fault. Just a thought.
    Silly question but this thing was dead on arrival right???????
    Alba European
