Results 1 to 10 of 35
Thread: The Cursed T4
Golf Loon The Cursed T4 05-05-2008, 09:42 PM
DUB 20V just torch it that wil fix it... 05-05-2008, 09:47 PM
Golf Loon Trust me, that has crossed my... 05-05-2008, 10:11 PM
gregozedobe Some random, oddball thoughts... 05-05-2008, 11:57 PM
TDI Dude Tend to agree with gregoz..... 06-05-2008, 12:58 AM
    Camden, Sydney
    The Cursed T4
    OK. We have this T4 2L that I cannot get to start.
    It turns over and has petrol to the engine, but will not start.
    So far we have checked and rechecked the timing.
    Changed 30 and 167 relay.
    Changed dissys, car, rotor, brand new leads, coil, plugs
    Fuel pressure reg, fuel pump
    Ignition switch.
    I have swopped another ecu, not expecting it to start and run, as this is a coded car, but if it starts and cuts out, its the ecu. Nothing, exactly the same.
    Temperature Sensor
    It has heaps of fuel, maybe too much and OK spark, not awesome, but enough to make noise you would think. Sometimes a splutter, but no bang.
    Engine has 140 compression on every cylinder.
    WTF it shouldnt be this hard on a 2L.
    Any ideas? My only thoughts for tomorrow are MAF, Intake sensor and Oil Pressure. Oh yeah and we killed the starter today too
    Mar 2007
    sydney
    just torch it that wil fix it lol put a 20v in it...
    mk4 the mods begin for round 2 hahahha
    Camden, Sydney
    Quote Originally Posted by DUB 20V View Post
    just torch it that wil fix it lol .
    Trust me, that has crossed my mind.
    Canberra
    Some random, oddball thoughts which may (or may not) provoke a productive line of thought (admittedly all weird stuff, but that's because you seem to have covered most of the conventional suspects already) :
    What was the immediate prior history ? eg it was starting and running OK until we changed the timing belt (or whatever).
    Is the spark "OK" when under compression (as opposed to when the spark plug is sitting outside the combustion chamber) ie is it still producing a reasonable spark when the plug is in the head ?
    Is the spark being produced at the correct time (and not 360 degrees out of phase - it would still look OK on a timing light if it was happening on the exhaust cycle rather than the compression/ignition cycle ).
    Does it have a crankshaft position sensor ?
    Any sign of an aftermarket kill switch (typically on ignition or injector electrics) ?
    Are the plugs getting wet with petrol, or just damp ?
    Blocked exhaust ? (although I would expect it to start and run for a few seconds at least).
    Is air being sucked into the cylinders and blown out through the exhaust ?
    Is there a broken engine mount allowing the engine to move so much it is allowing something to touch or stretch too much, thus stopping the engine from starting ? Try levering the engine into a different position and see what happens (this is one I have known to happen to a petrol T4 - drove the owner nuts for 18 months or so).
    Well that lot will give you some things to investigate for a while anyway, let us know what it turned out to be when you do get it fixed (even if it is embarassing for you , as that will add to the collective knowledge pool )
    Nov 2007
    Tend to agree with gregoz.. I'd lay bets its a sensor, more than likely a crank or cam sensor (if fitted). When hitting a brick wall like this I always find its best to leave the problem and walk away for awhile, then when you get back to it a solution normally presents itself. Good luck with it though and let us know what is was when it gets running again.
    GOLF GT SPORT TDI SUNROOF, XENONS
    Camden, Sydney
    Plugs are wet, almost like overfuelling, but it could be cos we have cranked it for so long.
    It does not have a crank angle sensor.
    It could be an intake sensor.
    I thought there would be an immobilizer, but the under dash loom looks virgin and unmessed with!
    I`ll keep you posted.
