Results 1 to 7 of 7
Thread: Roof Racks T5
    Dec 2007
    Penrith
    Roof Racks T5
    Has any one fitted racks to ther van, if so how many 2, 3, or 4 and what was the fit like as in level between bars and ease of fitting and what brands.
    Jan 2007
    I've got the VW branded ones that are OK, but not particularly heavy duty. Can still get the canoe on top, and get into many of the car parks.
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Jul 2007
    Quote Originally Posted by baldy View Post
    I have a Thule commercial roof rack set (4 roof bars) installed. The commercial bars have a stronger profile with T slots in the top, back, and bottom of the profile.
    The fit is excellent.
    You have a choice of a "low" or "high" foot. The low foot just clears the roof. I went with the high foot. The feet are mounted on the factory hard points on the roof.
    You can select the width of the roof bars. I chose just enough overhang to enable me to mount my awning under the bars but above the side door opening.
    I use the Thule folding load stops - they pivot horizontal when not in use.
    I also have a roller mounted on the rear most bar. This bar really needs to be at least 280mm closer to the tail. I have made up a 50mm spacer but I feel it still is not enough. When lifting ladders up onto the roof, you just clear the top edge of the tail gate before you slide onto the roller...
    No wind noise with the racks or with the awning for that matter!
    Dec 2005
    Rockhampton Qld AU
    G'day,
    Any chance of seeing some pics of your awning, inc some detail shots og the mount.
    Thanks.Neil
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Jul 2007
    I have posted photos on the Brickyard forum.
    My awning is a Howling Moon Alu Awn. Simple but gets the job done.
    Brackets slot into the bottom T slots of the Thule bars and into two (of the three) T slots in the side of the awning housing.
    I'm using the third T slot as an electrical conduit for my work lights.
    Adelaide, South Australia
    Hi MM
    can't find your pics on brickyard?
    GT
    Jul 2007
    Quote Originally Posted by tapsy View Post
    Hi MM
    GT
    http://www.brick-yard.co.uk/forum/fo...=163448#163448
