Results 21 to 30 of 35
Thread: The Cursed T4
  1. #21
    Canberra
    Anyone have any input?
    You have said previously that the spark wasn't real flash. If it is marginal out in the open air then it might not be strong enough when it is in the combustion chamber under high pressure with (possibly too much) fuel in the mix as well.
    If it is still getting wet with petrol in the combustion chamber I'd be suspicious of too much fuel, as it should only be getting damp.
    I seem to remember a rough spark plug test we used to do with old two stroke motorbikes (always fouling spark plugs) was to hold the spark lead about 2-3 mm away from the top of the spark plug as you cranked it over. If you couldn't see a good, clean spark from the lead to the plug terminal the plug (or the ignition) was suspect. Make sure you hold the plug lead with something very well insulated or you might get a nasty electrical shock.
    Failing that then it is (as previously suggested by Jmac), time to go back to first principles, taking nothing for granted and pretending you haven't worked on it at all (ie make sure it is getting air in at the right time, correct amount of fuel, reasonable compression pressure, good spark at the right time and it has to go boom ! )
  2. #22
    Camden, Sydney
    Got hold of a second hand manifold today.
    Changed the throttleboddy, still the same, changed the injector rail and it started, ran for a minute, then stopped.
    I reckon we will clean the plugs tomorrow and hopefully it will consistantly start.
  3. #23
    lol this one has been a pain hey
    cheeers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
  4. #24
    Camden, Sydney
    Quote Originally Posted by DVR68U View Post
    cheeers brenton
    Always the way when you take a job on as a favour.
  5. #25
    Camden, Sydney
    Still no go. Makes spluttering noises but wont go.
    Rigged up a crude node light from an LED and the fuel rail is not pulsing correctly. It is intermittant at best.
    Has to be ecu. Damn.
    Opened up the ecu, no obvious burnt tracks etc.
    Anyone got a 1996 on 2L ecu for a transporter?
  6. #26
    Canberra
    While you are waiting for an ECU, you might be interested in :
    Checking all fuel related electrical connections ?
    Checkin for broken (internally) wires ? (Unlikely I know, but easy to check with a multimeter, and imagine how you'd feel if you did get and install another ECU and you still had the problem ? )
  7. #27
    Sep 2007
    cessnock area
    Exclamation
    What with your starting problems and my husbands problems with the starter motor on our T4, my husband suggested maybe we should get together and have a big bonfire!!
  8. #28
    Peregian Beach
    Someone once told me that if the coil fails it stops the fuel delivery as well. If the spark isn't too flash then maybe the coil is suspect.
  9. #29
    Aug 2007
    Never heard of the coil doing that ???????????SPark is the output from the coil and that is not measured, only thing linked to the coil via the Ecu is the Hall sender. Im sure that would have been the 1st thing Matt changed.
    Loon check the pulse from the centre wire of the hall sender should pulse with crank and the 2 outer should be ground and ign live.
    Jmac
    Alba European
  10. #30
    Camden, Sydney
    Thanks guys. Finally laid this rest today.
    T4 dissy is not the same as Golf 3! The Transporter has no crank angle sensor so needs 4 windows in the dissy, the G3 dissy only has 1.
    2 Lessons there, 1. assume nothing, no 2 if you change a part and its not that, change it back.
    Oli noticed the dissy thing, thanks mate.
    Also scored a replacement ecu and the van now starts and drives sweet as.
    The original ecu starts the van and makes it hunt up and down and stall sometimes. If I put the replacement one in its all good.
    Phew, feels like a weight off my mind and thank God it now works.
