Mechanic, of course
I reckon it'll be the brake light switch.
Hello,..
I have a factory fitted cruise contol, that turns on, but then turns off when it needs to do some more work, like go up a slight incline, or it seems after 5min.
Do i go to the mechanic or a autoelectrician,..?
E
Mechanic, of course
'07 Transporter 1.9 TDI
'01 Beetle 2.0
yep..brake light swich 95% ...5 % chance cruise stalk itself..
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
My cruise does not turn on at all. Any ideas?
Probably the stalk.
'01 Beetle 2.0
Auto or manual?
Brake light switch. Check your lights
If its manual it could be the clutch switch also and quite common. The last 3 cruise issues i had were clutch switch. If you disconnect it and bridge the 2 pins on the plug...if it then works its the clutch switch at fault
