Results 1 to 10 of 13
Thread: Cruise Control not working. T5 2007 Auto
    Feb 2014
    Moorabbin, Vic
    Hello,..
    I have a factory fitted cruise contol, that turns on, but then turns off when it needs to do some more work, like go up a slight incline, or it seems after 5min.
    Do i go to the mechanic or a autoelectrician,..?
    E
    Dec 2008
    Sydney/Canberra
    Mechanic, of course
    I reckon it'll be the brake light switch.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    yep..brake light swich 95% ...5 % chance cruise stalk itself..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Oct 2013
    Fulham SA
    My cruise does not turn on at all. Any ideas?
    Dec 2008
    Sydney/Canberra
    Probably the stalk.
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    Auto or manual?
    Sep 2012
    Brake light switch. Check your lights
    Oct 2013
    Fulham SA
    Manual
    Quote Originally Posted by vdubmotorworx View Post
    Auto or manual?
    Oct 2013
    Fulham SA
    Is it a DIY job to change the stalk
    Quote Originally Posted by Umai Naa!! View Post
    Probably the stalk.
    Pretty sure all lights are working. The cruise hasn't worked for years as I got quoted over $500 to fix it from VW.
    Mar 2013
    Brisbane QLD
    If its manual it could be the clutch switch also and quite common. The last 3 cruise issues i had were clutch switch. If you disconnect it and bridge the 2 pins on the plug...if it then works its the clutch switch at fault
