Originally Posted by
harbourdj
The temp gauge sat slightly above the cold mark all the way.
I'm assuming the temp would be due to the outside temp of about 5-7 degrees C,Plus the fact its also been raining most of the way so that could be another factor.
My opinion is the temp is too cold. All diesels run halfway on the gauge [90 degrees C] I have not owned a petrol but in the interest of emissions & fuel economy the designers normally have them running quite hot.
Many years ago I owned a MK2 GTI golf. When I bought it is was running cool. The PO said it had always run at that temp. Not satisfied, I pulled out the thermostat & checked it & it was opening far too early. After fitting a new t/stat the fuel consumption improved considerably. BTW it's worth checking the new one before installing.
Numerous Mk1 Golf diesels
