Results 31 to 36 of 36
Thread: Cracked Manifold
  1. #31
    Jun 2011
    the gong
    Manifold bolted back on started up sounds like it should again no problems no leaks even though I reused the exhaust and turbo gasket not the best idea I'm sure but we will see how it works out. Keen to get some km's done to see if the fuel economy and power has improved.
  2. #32
    Jul 2005
    Newcastle, NSW
    I got an exhaust mani gasket but forgot to get a turbo one so better remember that. New brass nuts also.
    Now just finding the time!
  3. #33
    Aug 2013
    Brisbane, Queensland
    Ouch.
    Got quoted today for the job to replace the exhaust manifold on my T5. $1945.95
  4. #34
    Dec 2013
    Palm Beach. Queensland
    WOW, I cant believe they want to charge that much!! I took all the instruction above and it took me about 4 hours total, also did a oil and filter change at the same time. Yes it is a little fiddly to get to it but definitely not to hard to have a go. Tools are the key though, the turbo has 12 point internal needed (like a torx but with 12 points) they are 10mm and 12mm metric. Don't leave it to long though because the exhaust smoke that is around the engine bay will get sucked into the air filter and eventually block it and suck it up into the air box (it made a big thud when it did) I have also just had the 6speed auto serviced at 145000 Km's which is highly recommended.
  5. #35
    Dec 2008
    Sydney/Canberra
    Yeah, not an overly difficult job, but the manifold itself doesn't come cheap.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  6. #36
    Apr 2009
    Canberra
    Yeah the manifold for mine cost $1100 two years ago, has done 5oK km since and so far so good
    06 T5 4Motion
    aka Lola the Tranny
