![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Silver Caravelle
I would expect the opposite in terms of little flow to the header tank when the engine is cold. That is the purpose of the thermostat. The thermostat will restrict flow to circulating coolant around the engine block only for quick warm up until the coolant warms up to then open the thermostat to allow coolant to then circulate through the cooling system. That is why I wondered about a sticky thermostat if the engine temp went intially high then settled back to normal. Now if there is little flow to the header take when engine is warm, it could be a number of things such as air locks, dodgy thermostat and possibly the water pump.
Anyway all the best with it.
