Results 1 to 10 of 16
Thread: Sliding Window Repair Kit
    Dec 2006
    Kilsyth, VIC
    The drivers side sliding window (in the sliding door) on our T5GP has snapped the little plastic connecting bit on the latch end on the lower operating rod.
    Part number 7H0847788A.
    That picture isn't quite right, I need the bent rod, left to right they are inverted so the bent one on the passenger side is on the top like in the picture.
    The part is on back order from Germany from VW themselves (no clue what it actually costs either, but the latch is $92!!) so I can't order one from there. Given how tiny the connecting ball is I wouldn't be surprised to find this is a very commonly broken part... which begs the question why there isn't any spares from VW??
    But in having a hunt around I see I can order an after market repair kit with all the parts like this one:
    Bross Auto Parts BDP964 Side Sliding Window Glass Latch Cover Repair Set 7H0847788A, 7H0847781B, 7H0847785 for VW T6 Caravelle|Interior Door Panels & Parts| - AliExpress
    Same thing on eBay stores too, but nothing in Australia... so one day eventually when this shows up I will likely try and use just the rod I need, but for AU$16.83 delivered it's worth a gamble.
    Plan B will be to find one in a wreckers one day... I actually need a few little odds and ends (like the Multivan Step light) so maybe it's something I should look into sooner unless someone on here happens to be wrecking one?
    Jul 2017
    newcastle nsw
    hi,
    on a some what connected topic.the runners/guide for the sliding window(part #5)have come adrift from the glass.this prevents the widow from sealing when closed.the runners appear to have metal bracing inside which has rusted....
    has any one had similar problems?
    Dec 2006
    Kilsyth, VIC
    I should look closer at that as I've noticed that same window tends to leak during heavy rain, so I might very well have the same issue! I haven't really looked because I couldn't open the window and had'nt taken the time to pull it apart until yesterday.
    Jul 2017
    newcastle nsw
    both of my windows are leaking,,,,,perhaps I will use a sash clamp and timber to hold it in place and then Sikaflex.....
    Dec 2006
    Kilsyth, VIC
    The windows aren't used very often... so that's an option
    Nov 2020
    Hi I had the same problem ,some small plastic part of the lower latch broke it was definitely operator error , I bought the eBay one and used some of the old pieces mixed in with the new and have had no problems .It’s a little finicky to install and I dont think the quality is up to oem so I would say that I’m a bit more cautious when I use it now ,your mileage may vary if it’s used regularly but for 20 bucks vs 60-70 oem plus install I’m ok with it value wise.
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by GeoffDY View Post
    It's been broken for at least a year... so no, not used much at all. This is something I've been "getting to" for a long long while and I was reminded when I was giving the inside a good clean with the wet vac and went to open the windows and remembered I couldn't. I originally thought it had just popped off it's mounting, but the rod part has a tiny plastic end which has had snapped off. I could probably MacGyver something... might still have to depending on the quality of the repair kit!
    Nov 2007
    QLD
    I have also been through this, mine snapped off at the right angle at the operating butterfly levers.
    I went to all the trouble of ordering a repair kit from England containing four new rods, but they are so weak that two of them broke installing them, couldn't even use them.
    If you look closely at the right angle end, it look a lot like the hub end of a bicycle wheel spoke, so I went to a bike shop and bought four thick spokes, then cut them off and used thin aluminum tubing sleeves that I bought from a hobby shop. Then shortened the lock pin ends and glued them into the sleeves to join them to the bicycle spokes, but before glueing them I fed the spokes through the holes in the end that works them as they cannot be installed or removed once the sleeves are glued together. This all worked perfectly, and a million times stronger and better than VW's effort.
    Mt Cotton
    Bross are pretty good with delivery , on average before covid I could order and receive parts under 8 days now its around 12 to 14 days still pretty good .
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by BrianJ View Post
    I was thinking that even the stock ones looked a little weak for what they intended. Very similar to you I was looking at creating a rod/loop running through the mechanism rather than relying on the plastic ball joint. I was thinking you could do this with wire rather than a steel rod (so it is a little flexible and wouldn't damage the plastic eyelet it has to run through) then cut the stock rod in half and connect the two parts together using a screw connector like this:
    then if it loses tension you just tighten up the connector...
    Will see soon enough when the parts show up if I can use them or not.
