Results 1 to 5 of 5
Thread: Coolant hose
    Coolant hose
    My old girl broke down again.. Coolant going everywhere, I waiting till it cooled down then had a look and found the problem I had a spilt hose.
    I have found the drawing on this forum but I cannot find which number it is. The van is a 2.5 ltr petrol 1997. Hoping I get the replacement part pretty quick.
    [IMG][/IMG]
    Can any one give me the part number of size of the hose so I can order it.
    Many thanks.
    D
    Adelaide hills, SA
    It looks like a straight hose. It shouldn't be that difficult to get.
    Hi thanks for the reply, do you know i need to a like for like or can I just coolant hose from garage or supercheap and cut to size and replace.
    Also do you know what size is used, I havent pulled the spilt hose off yet so cannot tell what size it.
    Cheers,
    Adelaide hills, SA
    Any coolant hose with the same diameters will do. You need to take it off and measure it. All good parts stores should have a common 16mm or 5/8 heather hose, if that's what it is.
    Mt Cotton
    For the age of the van it would be a good idea to check all of the others as if one has perished god knows how close some others are to splitting as well , better now than out on the road .
