Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Clutch leaking fluid
    Jul 2017
    Raymond Terrace, NSW
    It's already had a ew clutch kit put in only 3,000 k's ago. Flywheel etc already done. The clutch is nice on it and gears change without a problem. It's just a failed slave but falls out of the warranty period. I asked for a written quote and he came back at $1,300 and not $1,200. I think if a mechanic gives you a written quote they can't add more to it when it comes payment time. Is that correct?
    Jul 2017
    Already had a new clutch in it 3,000 k's ago. Flywheels also been done. Just a failed slave cylinder. Done by Tony King at Karuah. I'm starting to think that some mechanics just seem to charge more because it's a VW
    Jul 2017
    All fixed thanks to Pete at Newcastle VW Centre. Highly recommended for any dub work...
    May 2006
    Adelaide South Australia
    Good result, glad it had a happy ending. Thanks for reposting.
    Numerous Mk1 Golf diesels
    Adelaide hills, SA
    Quote Originally Posted by Fossil View Post
    That was a good time back then to replace the slave cylinder as well.
    As per the written quotes, I always write down that if it would be more than +/-20% I call you to approve it, in other word, the quote is always within 20%.
    Mt Cotton
    When you think back to the old days Slave cylinders for gearboxes were on the outside with a simple lever mounted on a pivot that would depress the pressure plate , you only had to replace the kit if it leaked for around $30 or a new slave cylinder under $100 and it could be done in under an hour by anyone .
    Jul 2017
    Got it all fixed by Pete at Newcastle VW Center for $900. So glad I met him as not only is he a great veedub mechanic who certainly knows his stuff but also a very decent bloke. Highly recommended for any VW, Audi, Skoda or Porsche owners in the Newcastle district. Only regret is not meeting him earlier to do my services that cost way to much by a bloke who knew nothing about Transporters.
