Are you sure it's the clutch and not the flywheel?
Why do you think you need a heavy duty one?
Hello everyone, I have a failed clutch in my 2014 2 Litre Bi-Turbo 4MOTION Transporter. Wondering if anybody knows of a heavy duty clutch for this model. My mechanic can’t find anything heavy duty from his suppliers.
Thanks in advance.
Bruce CQ
2018 Crafter Runner
T5.1 6sp manual.
Maybe the dreaded DMF .
Yeah.......if it's not making a rattling noise, it will be the clutch.
Problem is, just changing the clutch only is inviting a flywheel problem!
As for the clutch, the bi turbo probably loads it more (not sure if its the same as my single turbo) but I carry over a ton a lot for one or two hours and blew a flywheel before I wore the clutch out (about 300k).
I seem to be wearing out drive shafts more than anything.
2018 Crafter Runner
T5.1 6sp manual.
No, no rattling noise, just the slip and smell. Yes I realise the DMF needs to be replaced at the same time. Only 80k, so I think the solution may be to give up reversing the trailer.
Some time back when I was asking about lower gearing on here for the T5 somebody did say, ‘just save up for a new clutch’!!! Looks like that time has come.
Thanks
Bruce CQ
Geeze......at 80k you'd almost gamble a flywheel if the clutch only lasted that long.
Let us know what happens.......and good luck!
(I don't tow anything but when I load/overload the van......it's all on the arse!)
2018 Crafter Runner
T5.1 6sp manual.
Well the job has been done, clutch and DMF so I’m much lighter in the pocket. Sooo I will now be limiting/eliminating my trailer reversing up slopes and my 4 wheel driving.
Bruce CQ
Numerous Mk1 Golf diesels
