Results 1 to 10 of 14
Thread: Clutch
    Mar 2014
    Gracemere Q
    Clutch
    Hello everyone, I have a failed clutch in my 2014 2 Litre Bi-Turbo 4MOTION Transporter. Wondering if anybody knows of a heavy duty clutch for this model. My mechanic can’t find anything heavy duty from his suppliers.
    Thanks in advance.
    Bruce CQ
    Aug 2016
    NSW
    Are you sure it's the clutch and not the flywheel?
    Why do you think you need a heavy duty one?
    2018 Crafter Runner
    T5.1 6sp manual.
    Mt Cotton
    Maybe the dreaded DMF .
    Mar 2014
    Gracemere Q
    Quote Originally Posted by LogicprObe View Post
    I assume it’s the clutch, was driving home from Brisbane (I live near Rockhampton) with about 160km to go, I slowed in a passing lane to let a truck pass and when I pulled out the engine revved away with no forward motion, except for momentum. I backed off and it seemed to take up and I carefully made my way home. The smell of what I assume was burning clutch when I got home lasted for more than 2 hours. The same smell I get when I’m reversing my trailer up a rise slipping the clutch. I miss the G and low reverse gear of the T3 syncro I had...
    I was hoping a heavy duty one may last a bit longer.
    Bruce
    Aug 2016
    NSW
    Yeah.......if it's not making a rattling noise, it will be the clutch.
    Problem is, just changing the clutch only is inviting a flywheel problem!
    As for the clutch, the bi turbo probably loads it more (not sure if its the same as my single turbo) but I carry over a ton a lot for one or two hours and blew a flywheel before I wore the clutch out (about 300k).
    I seem to be wearing out drive shafts more than anything.
    2018 Crafter Runner
    T5.1 6sp manual.
    Mar 2014
    Gracemere Q
    No, no rattling noise, just the slip and smell. Yes I realise the DMF needs to be replaced at the same time. Only 80k, so I think the solution may be to give up reversing the trailer.
    Some time back when I was asking about lower gearing on here for the T5 somebody did say, ‘just save up for a new clutch’!!! Looks like that time has come.
    Thanks
    Bruce CQ
    Aug 2016
    NSW
    Geeze......at 80k you'd almost gamble a flywheel if the clutch only lasted that long.
    Let us know what happens.......and good luck!
    (I don't tow anything but when I load/overload the van......it's all on the arse!)
    2018 Crafter Runner
    T5.1 6sp manual.
    Mar 2014
    Gracemere Q
    Well the job has been done, clutch and DMF so I’m much lighter in the pocket. Sooo I will now be limiting/eliminating my trailer reversing up slopes and my 4 wheel driving.
    Bruce CQ
    May 2006
    Adelaide South Australia
    Quote Originally Posted by Big Bug View Post
    By 80k, my neighbour's Nissan Navara had worn out 2 clutches. From memory around $3,500 a time. Same problem reversing a heavy trailer up a slope to his shed.
    His solution was to sell his ute & buy an Isuzu with auto trans. So far it's all good.
    Numerous Mk1 Golf diesels
    Sydney NSW
    Bruce CQ
    What was the damage?
    Sent from my SM-G955F using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
