Results 1 to 4 of 4
Thread: Climate Control Problem
    Mar 2012
    The driver's side climate control on my 2007 T5 Multivan Highline is blowing hot air regardless of what temp is selected. Passenger side and main cabin a/c are working fine.
    Do each of the a/c zones have their own fuses, or is it likely to be something more involved?
    Mar 2012
    A google search shows that this is a common problem in T4's with a valve/cable being the culprit. Do T5's with the automatic multi-zone climate control have the same valve/cable setup?
    Mar 2012
    Can someone point me in the right direction to purchase a VCDS (VAGCOM) suitable for my T5? Are the hong kong specials on ebay ok?
    I need to identify which flap actuator has failed.
    Mar 2012
    Got myself VAGCOM and scanned for the following results:
    Control Module Part Number: 7H2 907 040 C
    Component and/or Version: CLIMAtronic T5 4221
    Software Coding: 0011040
    Work Shop Additional Info: 7 HC5o9d0e7:0 4W9SDC 0D2i7s4p4lay_2_ClimaT5 X 0307
    Additional Info: Geraet 00000
    1 Fault Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    000 - - - Intermittent
    Hopefully the part number matches VW Australia, however how do i locate where it's located?
    Any other suggestions would be most welcome.
