Results 1 to 3 of 3
Thread: Climate Control 2009 T5 Caravelle - Only blows cold air drivers side.
    Hi Folks - The climate control for my 2009 T5 Caravelle 4motion has started to only blow cold air on the right regardless of the temperature setting. The passenger side seems to be ok. I understand this may be a "flap actuator " problem - possibly just a broken connector. Do you agree? (I have checked for fault codes, but the OBD unit indicates none are set.) The big question is how to I get access to the actuator and flaps to check? I have had a look but can't see exactly what I need to do to remove the necessary bits of dash. Can anyone help with details on how remove the lower dash panels? Thanks.
    Jul 2016
    Queensland
    Not sure if it will help you but I'm also guessing it's a flap of some sort. Have you tried resetting them? Try this.... YouTube.
    Thanks TheKiwi, I'll give it a go.
