Well, I spoke to the local tire guy on friday to get a price on some load rated alloy rims and he asked what tires i wanted.
told him i was looking at 225/65R17 BFG's AT. so we get past the whole it's not a 4WD thing, the VW Transporter is a N plated vehicle, so all good.
Ask's me if its got ESC (electric stability control). the T6 has ESP and according to QLD Transport, You can lift up to 50mm, but no tire lift...
So i double checked when i got home as i thought i'd sorted out the seikel lift and small tire increase was all good
Here is a copy paste of the QLD transport info, and also the original document.
I think he is right, the way i have read the document is it is a lift or tire increase, but not both
Lowering or Raising of Vehicles
A vehicle’s suspension can be raised or lowered by 50mm without specific approval, provided:
• at least two thirds of the original suspension travel in either direction is maintained
• coil springs remain in locating seats on full suspension droop
• the normal relationship between the front and rear suspension heights is
not unduly affected
• replacement springs have the same or greater load capacity as the original springs
• suspension coil springs are not shortened by cutting or heating
• leaf spring suspensions are not raised by the use of extended shackles, adjustable metal plates or by placing the
leaf springs to the opposite side of the axle
• if lowering blocks are used, they are either steel or aluminium
• the vehicle maintains a minimum running clearance of 100mm and the requirements in Australian Design Rule (ADR) 43 are met*
• the suspension of a vehicle fitted with Electronic Stability Control (ESC) may be modified without certification provided it is not combined with any other lift (i.e tyre and suspension, suspension and body block, etc).
*Generally, a vehicle which maintains a minimum clearance of 100mm between the ground and any point on the underside of the vehicle (except a point on a tyre, wheel, wheel hub, brake backing plate or flexible mudguard or mudflap) will meet ADR 43.
For more information regarding ground clearance and running clearance please refer to the LS section of the National Code of Practice for Light Vehicle Construction and Modification.
Alternative Rims and Tyres
Many vehicle owners like to replace the vehicle’s original rims and tyres with alternatives of different width, diameter and profile.
The following sub-sections outline the legal requirements for replacement rims and tyres fitted to a passenger car or derivative, or to an off-road passenger car (not including a light commercial vehicle), which will ensure your vehicle continues to comply with Queensland legislation, while allowing for your individual preferences.
For a passenger car, passenger car derivative or ‘soft roader’ (an all-wheel
drive vehicle that may be certified as MC ADR category), the overall diameter
of any tyre fitted must not be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that model.
The overall diameter of any tyre fitted to:
• a 4WD passenger vehicle specifically designed for off-road use (MC ADR category other than a ‘soft roader’);
• a 4WD goods vehicle and its 2WD equivalent if the chassis and running gear are essentially the same as the 4WD version (N ADR category); or
• medium weight goods vehicle (NA2, NB ADR category);
must not be more than 50mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that vehicle. Tyre diameters of a vehicle fitted with Electronic Stability Control (ESC) may be modified without certification provided it is not combined with any other lift (i.e tyre and suspension, tyre and body block, etc).
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUK EwjLw8XA0ODPAhVFHGMKHcFNAWcQFggbMAA&url=http%3A%2F %2Fwww.tmr.qld.gov.au%2F-%2Fmedia%2FSafety%2FVehicle-standards-and-modifications%2FVehicle-standards%2FVehicle-standards-instructions%2FG19.pdf%3Fla%3Den&usg=AFQjCNEWTtRf_ qZz3U9ns4qtUVwwS8tWew&bvm=bv.135974163,d.cGc
