Results 1 to 10 of 11
Thread: How low do you go?
    Aug 2008
    How low do you go?
    How low do you run your tank in your T5 TDI? I usually fill up just as the needle gets to the red. How much further will it go before running dry?
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Dec 2007
    Quote Originally Posted by Ivo View Post
    It'll go another 300ks at least.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Jun 2007
    Melb.
    I'm not sure about 300km to go when it's in the red. How many litres do you get back into the tank as this will be your best guide? Eg. If you need 70Lt to fill it up (it's about 80L usable) and if averaging 10L/100km you then had another 100km distance to empty.
    Let's just say lately I have been getting 81, 82, 85 (spoke to attandant about that one) litres into the 80L tank and have seen 0km range on the trip computer for a further 5 km before filling. When in the metro area, (and I'm feeling daring) generally when the fuel range distance gets to 10Km I try and find the nearest pump asap. Probably not the wisest thing to do.
    Adelaide hills, SA
    No more than 100km mate, idealy you sould fill up, don't go too low if you don't have to.
    May 2009
    The Hillz shire, Sydney
    It's a dub! It HAS to go LOW!
    1995GolfGlRocketShip!
    Apr 2009
    Seaford Victoria
    on many an occasion I have put in about 83 litres in an 80 litre tank. running too low? Incorrect van specs? or dodgy petrol bowsers?
    Sep 2008
    Gold Coast
    Distance to empty indicators are unreliable. I had an Falcon XR6 that ran out at 12km to go - 500m from the petrol station
    I generally refill as soon as possible after going into the red. Better safe than sorry...
    Aug 2008
    Most I have put in is 70lts to fill it up. So it sounds like I have another 10lts = approx 100km.
    What happens if you run out of diesel and the car stops, just a matter of getting a jerry cans worth in and it will fire back up like a petrol car or is not that simple being a diesel.
    Jan 2008
    Mallacoota, Vic.
    I've had 0km to go showing on the trip computer for a few Km a couple of times when I've underestimated the distance to the next servo on a trip. Doesn't make for relaxing cruising. Have also put up to 83 litres in. Probably not the best thing to do.
    Brian
    2007 T5 Trakkadu
    Adelaide hills, SA
    Not as easy as when you run out of petrol. You will get the air in the fuel system and you need to bleed it out otherwise it will not start.
    Ideally you should fill up fuel filter with the diesel first to get the air out of the fuel filter or you could try turning the engine over with the starter motor till it starts (no longer than 30s with 1 minute gaps between) risking that you flatten your battery and don't start at all.
