Originally Posted by
Sunny43.5
kordo does your van look like there are places for rear speakers at the rear if not I very much doubt there are speaker wires for the rear , you may have to run your own and fit the speakers in a suitable location if you have a look at the post on our T5 project I fitted speakers into the roof trim at the rear and just ran my own wires to suit . If you are trying to hook up extra rear speakers at the rear of the head unit there may not be any there at all from factory , probably the only vans that might have rear speakers and wiring standard would be the top of model ones only . Now if you are fitting a factory unit that has front and rear fade you may have to add the wires for the rear speakers at the plug if there are none there you are going to have to tap into the plug directly onto the back of the head unit somehow , I had a look on the back of our factory unit and it shows rear speaker outputs but I cannot remember if there were matching wires in the factory plug . As for changing the factory speakers [incidently they are probably made in China as were ours] you can but its a bit of a challenge as the speakers are actually moulded into the mounting that is riveted to the door inner skin . I just cut the old speaker out from the mounting frame and attached new ones of a much higher spec as I am running large amplifiers for front splits and the subs . Another interesting thing is that both of our other T5s from 2005 had factory tweeters fitted into the dash top at each end , those tight arsed bastards at VW did not bother with them on the new one along with a heap of other things the buggers left out as well .
