![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Sunny43.5
You should just try and remove the lens from either end of the front or rear , sometimes they have small locators the same each end or sometimes two at one end and one at the other . Unless someone has previously done the job its trial and error , using one of the Toledo trim tools you can insert it between the lens and the outer bezel and lever gently it should then come downwards from that side . Once its out you will see the locators , I often find they will just fly out once the one side is released .
