change a fuel filter on tdi t4/prime fuel system
right no better day then today to replace fuel filter, local garage dint do although i asked, i now understand why..
none the less.i bought this u beaut 350 $bentley t4 manual and its not helping..
i removed filter and put new filter back in, manual doesn't stayed fill filter or not, i assumed that since it does not say to fill it not to fill it, to for come contamination in your fuel system.
but how do i prime the fuel system, there is no hand primmer, is there a lift pump in the tank ?
also there is a white plastic valve that sits on top of the filter, it has a line in and out, im pretty sure it sits on the return side of system, what doe it do ?
thanks, mick
