Could eventually flog out the stud holes a bit
I am looking at putting a set of steel wheels on my T5 and I like the look of the ROH Blac Trak. Only issue is the centre bore size is 65.5mm which is 0.4mm bigger than the T5 hub size. Is this and issue as I doubt a 0.4mm spigot is feasible?
Any feedback much appreciated.
We fitted Holden Alloy wheels with the exact same stud pattern as the Van , when they fitted them they fitted a hub spacer to each wheel and they have been there for 12 years with no problems .PS before some one jumps on me yes they were load rated as they came off a Holden V8 Crewman . I have been checked by Qld Transport and they were all ok .
Not sure what your pointing out ours was to keep the wheel centralised once fitted not a spacer behind the studs .
I would see if its possible to get ROH to do the required centre bore as a special for you. Alternatively I would get the centre bored out further so a decent thickness centering ring could be made and fitted. On my Touareg the centering spigot on the hub has a slight taper to it to aid in seating the wheel so you may want to accurately check the diameter at the base of the spigot as it may be closer to the actual ROH wheel centre hole
2013 Touareg V8 TDI R line and spanner on my sons Mk4 R32
The wheels will wobble ever so slightly, even with only 0.4mm of a gap.
It will be noticable while driving (would drive me nuts) and will eventually result in uneven wear on the tyres.
