My last T4 transporter had dealer fitted central locking and immobiliser. I think the brand was Cobra. It was a dec '96 build update with factory immobilser and drivers side airbag, so in effect I had 2 immobilisers. The installer, from memory, didn't have much trouble fitting the solenoids due to the larger doors. I'm not sure if the end of the T4 run came with factory c/locking? What build date is your T4? Someone with greater T4 knowledge will soon pop in. I do remember that the installer used small multi-slotted mounting brackets to bridge across the top and trailing edge within the door frames to mount the solenoids. You would obvioulsy need to make sure a latter generation T4 factory c/locking kit even has mounting points in your van, otherwise it might be faster/less adrama to buy a new set and have some warranty.
