Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Can't find any info on '97 T4 central/remote Locking.
    Mar 2009
    Sunshine Coast Hinterland
    Tom,
    It might pay to have a squiz inside the back door before you run the wiring.
    The back door lock on lift up models has a 90 degree twist and park action on the outside key lock.
    Not sure if that will work correctly with the actuator push/pull on the same rod.
    The red inside emergency button works directly on the latch, regardless of the lock position.
    Still 3 out of 4 is worthwhile.
    Neil C
    Apr 2009
    Sydney, Australia
    Yes, I was wondering about that. The emergency lock probably isn't designed to lock and unlock all the time... I wonder whether there is a work around.
    Thank you. You have been extremely helpful. Has anyone had direct experience with fitting these systems?
