Why does my van start and then run after sitting for 3 months or more?
Just a quick update and question in case this narrows down the cause of my problem for anyone.
Haven't given up yet on my 2010 T5.1 that I've had since new...but haven't made the time or enthusiasm yet to tackle a job that's probably beyond my limitations.
My main problem continues to be when I start the van it runs for 3 seconds and then stalls, every time.
It seems to be an immobilser problem, which started after an auto elec tried some workaround while diagnosing my EGR fault code that probably wasn't the EGR and more likely electrical and related to fire extinguuisher residue.
Today afer 3 months with the battery disconnected (again), it started and ran.
(prior to this I had disconnected the battery for days and even a week without any improvement)
It is the second time this has happened now.
Previously before Christmas, after 2 years sitting with the battery disconnected, it started and ran for a couple of weeks.
Then the day after using Liqui Moly to try and remove the EGR fault and my first long drive, it went back to stalling after 3 seconds. Leaving me uncertain whether it has returned to the previous immobiliser problem, or was a new problem caused by me using Liqui Moly.
Now it seems likely it was just a return to the previous immobiliser problem, triggered by the first long drive
(I had taken it on a number of short drives over 2 weeks prior to that with no problems).
__________________________________________________ __________________________
VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
