He's going to maintain the same rolling diameter so no problem there
(I assume you are also looking for same width and offset)
Brake clearance, wheel and tyre load ratings are the things to watch
If you can't find anybody that has done this to your model you'll need to trial fit a rim
Need at least 3mm clearance to the brake caliper
