California Ocean @ Caravan Salon in Dusseldorf
Vitals
Highlights
-High Roof by Polyroof
-40cm LWB
-9m3 area of space utilized
-two-flame gas stove
-plywood coated kitchen
-42 litre fridge
-wardrobe in the rear
Three Engines
1.9 TDI 75 KW (102 HP) - 250Nm
2.5 TDI 96 KW (130 HP) - 340Nm (optional with 4Motion)
2.5TDI 128 KW (174 HP) - 400Nm (optional with 4Motion)
Originally Posted by
Google Translated Press Release
The California Ocean - exclusive study about travel mobile area has to be replaced true luxury and as well known by nothing. Now California Ocean with the study, which on 40 centimeters more wheel base at equipment can be realized, shows the Businesses Unit of Special Vehicles. The self-sufficient employment of travel mobilization ILS is always the center of attention thereby.
The basis of the study California Ocean places the transporter with long wheel base and a high roof of the company Polyroof. In this combination zirka nine cubic meters area are available in the rear. As well as a volume, that beside the used standards California above all a larger kitchen block permits a sanitary room with cartridge toilet and Handwaschbecken.
The driving apartment has in front a group of seats from a folding seat bank and the turned front seats. This arrangement at the same time forms the couch surface for the night. A angle kitchen from coated plywood with Unterschrank, rinse and two-flame gas digester follows in the center of the car, which are fed by 2.8 a kg gas bottle. A variable sanitary room with cartridge toilet and separate Handwaschbecken, installed left-sided in the tail, creates if necessary sufficiently distance from the Mitreisenden. Altogether 50 litres fresh water supply and a waste water volume of 30 litres are available.
In the tail California of the Ocean is accommodated also the wardrobe, which is characterised by a good accesibility, as well as 42 litres a seizing compressor cold box. Under the high roof is a further bed with slat rust, which can be folded down if necessary. A plastic window equipped with Verdunkelungsrollo and mosquito net permits thereby at night the view into the stars. A general-purpose table has its repository in the inside paneling of the sliding door. With up to four swinging out legs it can be used both in the vehicle and outside. Two suitable folding chairs are accommodated in „the double bottom ".
Three diesel engines are conceivable for the study California Ocean. As basic motorizing the four-cylinder with 75 KW (102 HP) and a torque of 250 Nm would be used. The five-cylinder promises more achievement. It mobilized depending upon performance level 96 KW (130 HP) or 128 KW (174 HP) and makes maximum torques available of 340 and/or 400 Nm. While the four-cylinder engine is coupled with a five-course transmission, optionally a six-course automatic transmission transfers engine performance to the wheels with the five-cylinder engine six-course switching or. The all-wheel drive 4MOTION is combinable with the five-cylinder engines.
Owing to the handy, comfortable and safe chassis the California Ocean in its daily handling will reach passenger car level. The independent suspension of the chassis consists of McPherson shock struts in front and “- feathers/springs and separate shock absorbers to a diagonal steering wheel axle with „Miniblok in the back. Beyond that largely dimensioned stabilizers suppress the side inclination of the vehicle in curves, while load-sensitive absorbers increase the suspension comfort. For necessary negative acceleration four ventilated brake disks provide. Are used Vierkanal ABS, ASR and ESP in series.
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
